Re: John, Jim, Rustred
Posted by Janicholson on January 08, 2013 at 19:26:49 from (74.60.94.18):
In Reply to: Re: John, Jim, Rustred posted by ldb on January 08, 2013 at 16:06:49:
Stone ground corn bread and a pat of butter MMMMM.
Assuming good battery voltage at the coil with the key on. Put the coil wire close to the engine block using tape to prevent being shocked. Turn on the key. Now wiggle on the points with a small screw driver to short between them, Do not bend them, just bridge the gap with the driver. This will make the spark jump from the coil wire. If not, the coil is bad. Jim
