Posted by RedRoundhead on January 09, 2013 at 11:34:23 from (24.106.38.186):
In Reply to: Precision Tools posted by d282 on January 08, 2013 at 08:05:33:
Don"t forget to get a Machinery"s handbook. And get two; the newest version, and an old version (pre-1968). They leave out some good, obsolete information in the newer versions. I have a 13th edition, and a 28th Edition, myself. I use them at work almost everyday, where we have a mix of old machine tools and new machine tools.
A set of gauge blocks, or some standards, to practice measuring on would be handy,as you can then find out what your "feel" is with different measuring tools.
If you order new tools like you mentioned, get ones with some calibrated standards; otherwise you are in the dark.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
