Posted by d282 on January 08, 2013 at 08:05:33 from (209.152.94.237):
I would like to start doing some measuring of engine parts instead of relying on the machine shop and plastigage all of the time. What tools do you have and what brand do you recommend?
Dial Caliper for general measuring Micrometer to measure bearings and the crankshaft Bore Gage to measure the cylinder bores 2"-6" Long feeler gages to measure piston clearance in the sleeve. (Am I correct on the above, and what else should I have?) Thanks!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
