Re: Manifold and Transmission Questions
Posted by kurt on November 02, 2000 at 14:53:13 from (63.69.63.151):
In Reply to: Manifold and Transmission Questions posted by Jeff Again on November 02, 2000 at 11:08:14:
i'll give you my guess on the second question first. it sounds like you are sucking air. have you tried re torquing to spec after it has run a while and then cooled down completly. alot of times everything will expand when it gets hot causing the gasket to get crushed then when things cool down your left with a gap where the gasket was not making good solid contact before. i don't have the torque spec or tighting order maybe someone else does.
as for the first question it sounds like you have an excessive amount of backlash in the gears involved in second gear. do you get this noise when going down hill and the transmission is holding the tractor back?
anyway just a guess and maybe a couple of things to check out.
Post A Followup
: Re: Re: Manifold and Transmission Questions
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
