the sequence is just start in the middle and go around in a circle till done. torque in three steps. i would do 40, 80 and then 110 ft lbs. the adhesive i use is permatex high-tack sealer. it is oil and gas resistant and holds the gasket in place. i have never had a reason to use coppercoat other than on bolt threads. many do use it on head gskts. thats another thing, make sure the stud threads are lubed with coppercoat, or neverseize lube. also once you get it running retorque the head and re -adjust valves to .017 once run for an hr. or so at half throttle. do adjustment while engine is still warm. have you removed valves from head and checked guides and valves and seats. also make sure no rust in guides. check the head for warpage with a straightedge also since it had a blown gskt.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
