Re: Farmall SMTA Valve chatter issue
Posted by Janicholson on January 16, 2013 at 06:36:30 from (199.17.6.21):
In Reply to: Farmall SMTA Valve chatter issue posted by Brady miller on January 15, 2013 at 19:48:33:
Valves dont clatter unless loose or over reved (3000rpm would do that, but unlikely to be your issue) What you are likely to be hearing is spark knock. I believe your timing is either too advanced (possibly wrong timing mark, or other measurement issue, or the advance is not working.
Another issue is fuel. If a 450 head and other compression enhancing factors like bigger bore, or popup (domed) pistons were used it might need 92R+M/2 Premium fuel. If you find fuel to be the issue, retarding the spark with a different cam plate in the centrifugal advance might be a way to avoid knock and use regular. Jim
Today's Featured Article - Restoration Story: Fordson Major - by Anthony West. George bought his Fordson Major from a an implement sale about 18 years ago for £200.00 (UK). There is no known history regarding its origins or what service it had done, but the following work was undertaken alone to bring it up to show standard. From the engine number, it was found that this Major was produced late 1946. It was almost complete but had various parts that would definitely need replacing. ... [Read Article]
