Super A antifreeze in oil
Posted by Farmall dean on January 16, 2013 at 14:15:15 from (216.228.194.178):
Rebuilt 1950 SA about 15 years ago. [Did not replace sleeve o-rings]. Probably torqued head to 65ft-lb.Have read threads on subject. Will check compression before dropping the loader frame and removing pan. Will look for antifreeze around sleeves and let it sit. There is a very small amount of oil that seeps out at head gasket area, also. Change oil 2x/yr. Use about 100-150 hrs/yr. Good oil pressure. No smoking. Add very small amt of antifrezze once/yr. Any other suggestions before I dig into it??
