I know nothing specific about that engine, but will say it sounds like low comp ratio. This is usually caused when repairing by reseating the valves into head too far. Most diesels you cannot reseat even one time without running into low comp ratio. Problem is, I have no idea what their protrusion or recession should be . Also, many times a thicker head gasket than original seems to find it"s way into production. If it works good under a load, I am sure that is your problem. I did notice you said .010 end gap, that is pretty tight as that has to be at least a 3.5 inch bore or most likely larger. Late timing is about only other thing and or very low volitility of the fuel.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
