Re: B-450 Diesel Terrible smoking and raw diesel out of exha...
Posted by frazier2cyl on January 16, 2013 at 16:44:33 from (166.137.156.162):
In Reply to: Re: B-450 Diesel Terrible smoking and raw diesel out of exha... posted by pete 23 on January 16, 2013 at 16:32:38:
I hope you are not right. It did not take much to clean up the valves or seats. And it"s starts so easy most diesels with low compression are hard to start or you have to use starting fluid. It"s starts right up. Also most low compression diesels get better when warm as everything swells. This thing is as bad at 40 degrees as it is at 180 I bumped the timing up a little earlier. It might have helped a little but made the engine noisy in the top so I slowed it back down. I pulled the exhaust manifold off and #1 and #4 are soaked with diesel. I am taking the injectors back in the shop tomorrow and put them back on the tester. I can"t help but think that"s where my problem is. Maybe the pattern is visibly bad now. And on the ring gap. It is a 4" bore. Agreed .010 is tight but makes me feel better about there not being any compression loss there. Tight clearance was intentional I plan on putting a turbo on it later if I can get the smoking fixed.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
