It does use the pre-chamber/cup style. Kinda a strange design the nozzle is part of the lower chamber which bolts into the head. Then the upper part of the injector with the ajustment screw and such bolts to the cup. You have to have the upper part and the cup all together to pressure test the injector then put it all back into the head as an assembly. Kinda resembles the large injectors on a IH 460-560. Ring gap was checked about two inches from the top of the bore. Used perfect circle rings With the top chrome, two steel compression and the expander type oil. All compression were .010 to .012 . Rings are in correct with bevel the right way. After I check the injectors one last time I'm going to make some kind if adapter for the glow plug port to check compression. I believe diesel has to have psi of 300-325 just to burn. Injectors are english CAV and so is inj pump. This is a fairly rare tractor in the US but wondering if its worth the headache.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
