Re: Manifold and Transmission Questions
Posted by kurt on November 03, 2000 at 14:41:49 from (63.69.63.251):
In Reply to: Manifold and Transmission Questions posted by Jeff Again on November 02, 2000 at 11:08:14:
yep, sounds like one or more of your gears are worn. have you checked for any broken teeth on them? someone may have the specs on the wear for the gears, but if it wasn't to costly i would look at replacing first and second gear sets since they are used more. the others may be fine. and that was a good ideal on the other response about having the manifold trued. you can also take a straight edge and a feeler gauge and see how far out it is. push comes to shove you can true it up with a file. this takes alot of time and you have to keep checking after every couple of strokes.
Post A Followup
: Re: Re: Manifold and Transmission Questions
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
