Re: Puzzling problem - IH 284 -- intermitant stuck transmiss
Posted by Janicholson on January 20, 2013 at 08:57:51 from (74.60.94.18):
In Reply to: Re: Puzzling problem - IH 284 -- intermitant stuck transmiss posted by escottpeterson on January 20, 2013 at 08:23:23:
The brakes are hydraulic (as shown in the caseih.com on line parts description) As such they should move at the pedal about an inch before doing any braking. If one pedal is rigid, and does not move, it could be that the brake cylinder is mis adjusted and not allowing the pressure to be released. The piston in the master cylinder for that brake must retract all the way to the limit of the bore. if it doesn"t. or if the cup is swelled up covering the compensating port, the brake will stay on. If both wheels are in the air, and the engine is off and the trans is in any gear, one tire should spin forward moving the other backward (differential) easily. If not, there is an issue with either brakes (I hope because it is easy) or a bearing, Jim
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
