Re: 966 tach not working
Posted by Tristan in MN on January 20, 2013 at 15:42:07 from (69.42.251.181):
In Reply to: Re: 966 tach not working posted by GordoSD on January 20, 2013 at 11:49:49:
As a matter of fact is fairly clear and seems to be in good condition. I have not pulled it apart or anything yet. I will have to check to see if the shaft turns. thanks
