Re: FARMALL 460 Stalling Issue
Posted by pete 23 on January 21, 2013 at 20:01:07 from (74.32.229.189):
In Reply to: Re: FARMALL 460 Stalling Issue posted by teddy52food on January 21, 2013 at 18:51:45:
Speaking of venturi's, last year, friend of mine called me over as he had the carb off a half dozen time and called me a few times. Tractor ran like a dream at idle, needed almost full choke to run wound up. I pulled carb and he had the venturi in upside down. Not many carbs you can do that on, I believe it is the marvel schebler. Can't put it in wrong on a 460 but could leave it out. Main nozzle can be left out also or damaged.
