Re: FARMALL 460 Stalling Issue
Posted by RJG on January 21, 2013 at 21:06:48 from (74.46.209.110):
In Reply to: FARMALL 460 Stalling Issue posted by pete 23 on January 21, 2013 at 20:01:07:
The venturi on this one only goes in one way, and I sure would have noticed if I'd left that big sucker out. The main nozzle looks pretty good on it.
I'm a pretty fussy guy when it comes to taking thinks apart and reassembling. I keep a real clean work area so I can see what came out and what has to go back in. I'd sure be upset if I finished working on a carburetor and had parts left over.
