I set the timing for 30 degree advanced at 1900 RPM and then checked it back down at Idle speed of 450 RPM and it was real close to TDC. I think all of that is OK. And yes...this tractor is stock as far as I can tell.
If I gun the throttle it immediately dies, if I slowly bring it up, it doesn't seem to have a problem. But if I put load on it at the higher RPM is will die, but I'm assuming that's because the governor is stepping in and basically gunning the throttle. I think it's still pointing back at the carburetor.....
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
