Re: C113 heads
Posted by Jim Becker on January 22, 2013 at 16:19:08 from (173.74.120.222):
In Reply to: C113 heads posted by Mr farmall on January 22, 2013 at 09:19:25:
The gasket for the water pump had reduced passages, I presume to balance the flow at all 4 cylinders. It was used on the C-113.
I am not sure if this link will work.
http://partstore.caseih.com/us/parts-search.html#epc::mr56559ar868662
