Re: C113 heads
Posted by CNKS on January 23, 2013 at 18:55:11 from (216.144.104.128):
In Reply to: Re: C113 heads posted by Jim Becker on January 22, 2013 at 16:19:08:
I stand corrected--and my statement about the 123 gasket being modified to give more flow is wrong--the holes in the gasket are smaller and would give less flow without the water pump, the balance you stated is probably the reason for the smaller holes. I went brain dead for a while in my 1st post because a couple of years ago when I overhauled my SA with no water pump, the seller of the gasket set included a C123 gasket -- they replaced it when asked.
