Re: Update on Farmall H Loose lift-all drive shaft.
Posted by pete 23 on January 23, 2013 at 18:56:50 from (74.32.229.189):
In Reply to: Update on Farmall H Loose lift-all drive shaft. posted by John in ct on January 23, 2013 at 18:46:34:
Both the transmission nut and the pump drive nut tighten clockwise. As trasmission nut is doing the driveing and the pump nut is being driven they both tighten when in use. You do not want that shaft between pump and transmission tight. It should be free fit or you will damage pump. It floats on the couplings. Should not flop around but just float.
