Update on Farmall H Loose lift-all drive shaft.
Posted by John in ct on January 23, 2013 at 18:46:34 from (107.194.110.54):
I am thinking that when I used my Lift-All, the round nut never loosened up ( turned counter clockwise) to make the drive shaft a tight fit. I decided to loosen the round nut ( Turn it counter clockwise) with a pipe wrench and now got the drive shaft really tight. I am wondering if I could get it too tight and put too much pressure on the shaft coming out of the transmission or on the shaft that drives the Lift-all pump? I also put some blue Locktight in the round nut before tightening it. Thanks!
