Re: Update on Farmall H Loose lift-all drive shaft.
Posted by wayne in mn on January 23, 2013 at 19:32:33 from (71.8.151.79):
In Reply to: Update on Farmall H Loose lift-all drive shaft. posted by John in ct on January 23, 2013 at 18:46:34:
The drive coupling is supposed to be tight against the shaft so oil doesn't leak past the threads. It will "self tighten" with normal operation. Same principle with the coupling on the pump.
Loctite will REALLY give you a problem when needing to change the seal later!
