Posted by pete 23 on January 24, 2013 at 08:11:51 from (74.32.229.189):
In Reply to: 1466 oil pressure posted by cttrestoman45 on January 24, 2013 at 07:05:23:
I think you are on the right track with replacing seal and possibly pump. Those pumps do wear out and the splines driving pump get bad also. The pump does not drive off all splines at same time so you can usually find splines that are not worn to install inner rotor on. If you need to replace the splined sleeve, you crack it with a chisel while supporting shaft. Heat new one in oven and install really quick.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
