I worked on it today. I took the round nut off, the Locktite wasn't too bad because there must have been oil on the threads. I reassembled it with the biggest cotter pins that would fit. I bent the ends over so they won't catch anything. If I turn the shaft 1 turn in to the transmission, the drive shaft is loose. If I then turn the driveshaft out 1 turn, the driveshaft is tight against the round nuts. I left it loose. I guess my concern is that if the driveshaft is loose, there may be wear problems. Thanks!
