Re: H starting problems...from A-Z....help
Posted by old on January 24, 2013 at 18:12:26 from (209.86.226.40):
In Reply to: Re: H starting problems...from A-Z....help posted by JJ1466 on January 24, 2013 at 18:03:27:
Most of the old tractors be they Farmall or the others had sat for long times so I made it a point to do the ATF thing before even getting them off the trailer. Many I would load, pull the plugs and fill the cylinder with ATF put the plugs back in and then chain them down. Then after I get them home I say to heck with it and leave them sit till the next day. Sat a 12 volt battery on pull the plugs out and step back and watch the ATF fly. So far doing that has gotten most to start up and yes smoke for a few minutes but still run
