Re: H starting problems...from A-Z....help
Posted by JJ1466 on January 24, 2013 at 18:03:27 from (108.245.218.22):
In Reply to: H starting problems...from A-Z....help posted by JJ1466 on January 24, 2013 at 17:50:06:
i did a compression test on all the cylinders...from front to back...100,95,95...75ish-80...that was the cylinder that i had to do some valve work to....i was afraid you would say that old, your good with your IH's
