Re: H starting problems...from A-Z....help
Posted by rustred on January 24, 2013 at 18:23:52 from (69.58.16.5):
In Reply to: H starting problems...from A-Z....help posted by JJ1466 on January 24, 2013 at 17:50:06:
is the firing order correct, 1342 is the order. no mension that you confermed it. also have you checked or even changed the oil bath air cleaner? have seen them frozen with water from the rain and that prevents starting. with that compression it will run. also with it blowing out the air cleaner, better make sure you have the valves adjusted properly. .017 hot, but set them to .019 cold for the first start. then when doing the head retorque you can set them to .017 after engine has been run.
