Posted by Patrick HMD on January 25, 2013 at 13:51:37 from (75.16.102.193):
Now that I have installed my pulley gearbox I was advised to pour a quart of lube at the top filler to be sure the gears are lubed before start up. Not knowing what kind of gear lube is in there now, I bought a quart of Traveller SAE 85W-140. Will that do?
A large amount of lube oozed out the oil fill inspection hole when I removed the plug, maybe 1 or 2 quarts, but no water. I'll leave the plug off till after I add the quart to the gearbox which will probably bring the oil level up a bit more. An over filled gearbox is not a good thing I've been told. It will cause leaks where there shouldn't be any.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
