Re: Super C Governor Problem
Posted by Janicholson on January 25, 2013 at 17:38:28 from (74.60.94.18):
In Reply to: Re: Super C Governor Problem posted by Bud W on January 25, 2013 at 17:22:23:
If the shaft end wiggles up and down more than 1/16" I would replace the main bearing. The Bumper spring assembly might be easiest to remove when it is out of the tractor. Then (as far as I can see, it will require some solvent, and careful manipulation to get it free. jim
