Re: Super C Governor Problem
Posted by Bud W on January 25, 2013 at 17:58:52 from (70.242.114.188):
In Reply to: Re: Super C Governor Problem posted by Janicholson on January 25, 2013 at 17:38:28:
Do you have a part number for the main bearing? I don't see it in my parts book. Funny thing is this problem happened after the tractor had set for a month or two. Everything was fine when I shut it down. Its kind of like a catastrophe failure versus a worn bearing. Would it make sense that the fact that the shaft bumper will not extend could allow the pinion and everying thing attached to slide forword causing my problem???
