Re: C 291 hesitation
Posted by Jim Naden on January 27, 2013 at 10:00:41 from (12.74.50.125):
In Reply to: C 291 hesitation posted by Icuby on January 27, 2013 at 09:05:15:
Converting to an adjusting screw won't help the stumble.
Make sure you don't have a vacuum leak between the manifold and cylinder head.
Check the throttle shaft for wear, if it's loose the vacuum leak there can contribute to off idle hesitation.
Low fuel level in the carb could cause problems.
Looseness in the advance mechanism can cause the timing to flutter around at low speed.
Could be a combination of all those issues too.
Jim N.
