C 291 hesitation
Posted by Icuby on January 27, 2013 at 09:05:15 from (174.225.134.42):
This has probably been discussed before but I can not find it. This will die out when cracking the throttle if you dont grab the choke right a way. It does have an electric shut off at the carb. that is working ok. Would a mechanical screw work in place of this electric solonoid and get the problem solved? Thanks
