Posted by pete 23 on January 27, 2013 at 10:58:33 from (74.32.229.189):
In Reply to: C 291 hesitation posted by Icuby on January 27, 2013 at 09:05:15:
Lots of discussion on this subject. Main problem, rarely addressed properly, is that the heat riser needs attention. Requires splitting manifold, cleaning all the passages surrounding the heat stove inside, having a good valve plate inside, properly set so counter weight is straight up and down when cold and you need a good thermostatic spring. I have repaired many, many over the years as the same exact system from 460 to 806 gas. This doesn't replace a good proper tune up but is a direct part of the tune up.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
