Re: Differential tooth pattern-not sure what to do
Posted by Zachary Hoyt on January 29, 2013 at 09:02:46 from (50.122.169.86):
In Reply to: Re: Differential tooth pattern-not sure what to do posted by The tractor vet on January 29, 2013 at 08:44:40:
Thank you. I do not know what coast means in a gear set, and I do not have a dial indicator so I have to guess about the back lash. The best that I can currently tell from what I have done is that the lower half of the tooth on the pinion is driving the upper half of the tooth on the ring gear. This would seem to me that it could indicate that I should take out a shim and put the pinion further into the rear end case. I am also wondering if moving it further in there would be likely to make it whine or be too tight. I have only done this sort of thing once before and that time I put a used SH pinion with its shims on a used H ring gear and it seemed to work fine, although I did not check anything other than visually and by feel and did not check the mesh. I am not sure whether to just put this together the way it is and see if it works or try to adjust things and maybe get myself into a worse mess.
Zach
