Re: Differential tooth pattern-not sure what to do
Posted by The tractor vet on January 29, 2013 at 09:53:29 from (75.19.126.114):
In Reply to: Re: Differential tooth pattern-not sure what to do posted by Zachary Hoyt on January 29, 2013 at 09:02:46:
Things ya need as far as tools ya need , (1) dial indicator with a magnetic base -, (2) a set of Mic.'s 0-3 inches to start with (3) a set of depth mic.'s . And all can be had vfor not a ton of money as you do not need Starrets . And (4) a dial caliper . And since you are not sure what your doing then see if you can find someone to come over and help. If you were close i would do that.
