The stock Coil for a Farmall is a 6 volt coil and the use of a resistor is used from the factory , on late model 706-806 the ceramic resistor was replaced with a resistor wire . A hot shot wire as i cll it was run from the R terminal on the solenoid to bypass the resistor to give a shot of 12 volts for fast start and hot spark. Now i am not and electrical engineer and maybe my way of doing something are shell we say barnyard engineering i try and follow the book with a few teaks here and there like i do away with the fuse and use self resetting curcit brakers add in C/V relays to take the load off the head light switch when someone want to add more lights then came from the factory since you pushing the factory switch to the max at five lights . I cringe at some of gen to alt. change overs that i have seen , Like running a 65 amp alt thru a 12 ga. wire and like the Farmer wire job that was hacked up on this 460 i am working on at this time . How these guys can sleep at night with something like this setting in a barn full of hay and fifty or so cows down below is unbelievable .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
