Re: Ih460 wiring ,coil question
Posted by John T on January 30, 2013 at 15:37:14 from (71.52.103.159):
In Reply to: Re: Ih460 wiring ,coil question posted by The tractor vet on January 30, 2013 at 07:15:59:
Thanks for the info,I know many 12 volt tractors use the 6 volt coil and the ballast by pass while cranking, but I had no idea WHICH MODELS. The R or I (what Fords used) terminal on the starter solenoid is a terminal thats hot ONLY while the starter is engaged and it connects direct to the coil input so it sees unballasted battery voltage ONLY while cranking fOR TH hotter starting spark, its a good system if all is well...
Fun chat
John T
