Posted by pete 23 on January 30, 2013 at 16:48:11 from (74.32.229.189):
In Reply to: 706 gov. posted by farm-al on January 30, 2013 at 13:24:33:
Probably a worn thrust bearing. They have to be really good to work properly. Weights and pins of course have to be in good shape but even new they are not really tight. Link from governor to carb has to be set properly, throttle wide open, butterfly on carb wide open, adjust clevis to just that length, loose pin, no pressure. Bumper spring has to be firm on fork to work. Adjust screw in so no surge at mid rpm but still able to idle way down slow. The carb bushing and shaft also wear bad in those . Also, make sure the nut on end of shaft is tight as there is no key driving the gov shaft. I have seen them get pretty wild when that nut was not tight.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
