Posted by Hugh McKinney on January 31, 2013 at 12:02:38 from (99.195.66.68):
Well I just got my Behlin torque generator back from Steel Wheel Ranch, and everything is in place, good pump, all new lines, system flushed out, refilled with fresh fluid, but my power steering isn't working, much. I know I've got plenty of pressure at the pump...I think that I have air in the lines...which ones do I need to crack open...all of them? Pressure and return lines? Also, if my priority flow divider valve is not working, how does a person go about determining for sure that it is the problem? Thanks to all in advance, Hugh.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
