Re: 450 LP Power Steering, getting air out of system.
Posted by Centex Farmall on January 31, 2013 at 13:14:20 from (166.137.116.22):
In Reply to: 450 LP Power Steering, getting air out of system. posted by Hugh McKinney on January 31, 2013 at 12:02:38:
You and I still working on the same thing!
I did get mine primed and working but it still loses prime after it sits a while so I'm going to have to get into the rest of it. Possibly the gasket between the reservoir and the valve bodies is leaking.
I broke the pressure line after the pump loose and cranked the engine with the starter to very fluid pumping there. Next I took the pressure line off of the Behlin unit and directed it at a bucket and started the engine. After a short bit it spit out a couple of blobs of oil and then went to pumping. I shut down and re-hooked the line to the Behlin and everything worked after that.
Need to add that I initially had to give the reservoir slight pressurization with a rubber tipped air gun pressed against the hole for the vent.
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
