Posted by Farmall dean on February 01, 2013 at 10:03:30 from (216.228.194.190):
On 1/16/13 at 14:15 I posted a problem with my SA with coolant in the oil. After reading all the comments I checked the compression dry and wet with a warm engine. They were 100, 100, 100, 100 dry and 115 acrss wet. I pulled the pan and looked for antifreeze around the sleeves-nothing. Then I put a piece of formica under the engine for a week and waited. Still no antifreeze. Removed the head. Head looks good and is not warped. No Cracks. On the valve train I noticed two of the valve lever adjusting screws were noticeable more warn than the others. One was stuck to the push rod when I removed the valve lever assembly. I would like to replace the two screws but don't know where to purchase them. Can someone help me there with a phone number?? Replacing head-I will clean head and block thouroughly and wipe with brake cleaner, spray the gasket both sides with Permatex Hi- Tack sealer and torque in 20 increments to 80 lbs. Warm engine for 1/2 hour, readjust valves and retorque. What have I forgot??? Dean
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
