Farmall Tractors Discussion Board
Re: IH 350 Diesel troubleshooting, manuels,parts
Posted by F. Mellott on January 15, 1999 at 11:31:16:
In Reply to: IH 350 Diesel troubleshooting, manuels,parts posted by keith on January 14, 1999 at 17:34:21:
The lack of power problem may be one of two things. A poor injector or carbon around the piston rings. We had a 450 (semidiesel) act the same way. The problem was that the tractor had sat for a long time before we acquired it and the rings on one of the pistons would stick as the eninge temp. changed, causing it to miss. Later the tractor would run fine. Solution: clean the ring grooves on the piston and install new rings. try the injector first.
Post a Followup
: Re: Re: IH 350 Diesel troubleshooting, manuels,parts
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
