Re: Coil External Resister
Posted by Heat Houser on February 03, 2013 at 20:02:34 from (192.43.65.245):
In Reply to: Re: Coil External Resister posted by Bud W on February 03, 2013 at 19:01:13:
What tractor are you dealing with? My JD4010 gasser has the resistor as part if the ignition switch. My 560 farmall has it mounted by the coil. My B farmall does not have one as it is a 6 volt system.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
