Re: Coil External Resister
Posted by John G. Hasler on February 04, 2013 at 17:52:22 from (174.124.25.60):
In Reply to: Re: Coil External Resister posted by Bud W on February 04, 2013 at 17:33:17:
If you install a 12 volt coil of the type that has an internal resistor then you should remove the resistor that you are using now.
