Re: Coil External Resister
Posted by Janicholson on February 04, 2013 at 18:28:12 from (74.60.94.18):
In Reply to: Re: Coil External Resister posted by John G. Hasler on February 04, 2013 at 17:52:22:
Dear John With no disrespect, there are no internal resistors in coils. The 12volt for use with no external resistor does not imply that there is an internal resistor. There is not. It is just wound such that it can operate on full 14.2 volts of an operating charging system.
Bud's tractor has a 6 volt coil of unknown operational status. (we think it is bad)
he needs either a new ballast resistor, and a new coil, or a new coil only. If he purchases a 12v No external resistor required coil he can dispense with the ballast resistor all together.
That is part number MPE IC 14SB (no resistor required 12v. Jim
