Posted by Patrick HMD on February 10, 2013 at 23:57:15 from (75.0.239.150):
I have a major oil leak in my right brake pinion shaft, Upon removing all the parts to get to the oil seal, I noticed a little seepage around the brake pedal shaft seals. Decided to fix those too. As soon as I pulled the pedal shaft out, oil started seeping out. Then I removed the the plug that checks the oil level and it started oozing oil out too. I then put a 5 gal. bucket under both outlets and so far it's about 3/4 full. Anyone else ever experience this? I do realize that water displacement is the cause of all this. I also think that the excessive amount of fluid may be the cause of the oil leaks. If not all of them, maybe some.
I also have a leak around the belly pump area. Looks like toward the rear which makes me suspect the tranny oil seal maybe leaking. Not sure if the excessive amount of fluid is causing this or the seal needs replacing. If I do have to replace the seal (of which I have no clue as how to) will I have to drain the tranny before getting to the seal? What say ye?
Everything else in the rear area is super dry and tight. I'm planing on doing a good drain flush with some diesel later on.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
