300 update and belt pulley starting question
Posted by Zachary Hoyt on February 11, 2013 at 15:41:22 from (50.122.169.86):
I took a shim off the pinion shaft over the weekend since the
shaft I took out had one each of thick, medium and thin. The
one I had put in had the same with one extra thin one, so I took
that out and figured I would see if that helped with the noise or
not. Today I got everything back together enough to make a test
run but the tractor would not start at first and then the starter
quit. The relay clicks and the output side of the relay has 12
volts when I push the button but the starter does not roll over. I
knew it was not the best so this was not a huge surprise. I am
wondering if I should send it out to be rebuilt or buy a rebuilt
one off this site or buy a new one off ebay? In the meantime I
want to get the 300 running to see if the sound is still there so I
am thinking that tomorrow I will try starting it with the Allis C
and a flat belt. I have never done this before so I am wondering
how to do it for best results. I know I need to put a twist in the
belt so the engines are both turning the right way. I am thinking
that I should block the clutch on the 300 and put the belt pulley
in gear, start the belt running on the C and then get back on the
300 and engage the clutch, start the engine and then reverse the
process to get the belt off again without grinding any gears. Is
this an okay way to do it or is there a better way? Any advice will
be much appreciated.
Zach
