Re: 300 update and belt pulley starting question
Posted by Centex Farmall on February 11, 2013 at 19:29:51 from (166.147.72.149):
In Reply to: 300 update and belt pulley starting question posted by Zachary Hoyt on February 11, 2013 at 15:41:22:
Zach, I've had the same problem with starters here and there and it's usually the copper contactor disc inside the solenoid. It gets arc damaged over time and combined with a little corrosion it will stop working. Remove the phenolic cover on the solenoid and you will see the copper disc. It can be filed or sanded smooth. If it's particularly worn you can sometimes turn them 90 degrees and get more life.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
