Re: WD-9 firing order
Posted by rustred on February 12, 2013 at 10:40:50 from (209.115.232.65):
In Reply to: WD-9 firing order posted by green mann on February 12, 2013 at 10:18:11:
1 3 4 2 counter clock wise with # 1 wire at 2 oclock position is the way it should be unless dist. timing was changed.
