Re: Wiring diagram late model 140
Posted by Haas on February 12, 2013 at 14:31:44 from (50.142.111.41):
In Reply to: Re: Wiring diagram late model 140 posted by TheDurk on February 12, 2013 at 14:04:55:
My email is open on the forum, so send me an email that way
and I will reply to it a then you can send the scan. I don't like
posting my email address on the forum because it invites
spam. Thanks. I wonder, do you have the owners manual for
your tractor. I have another 140 with the generator and that
has the best wiring info I have found, but of course the switch
is not the same. I spent a couple hours with it and a
volt/ohmmeter and I have all working except the flashers. I
suppose the light switch is supposed to connect to the turn
signal switch, but can't determine how that goes.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
