Re: Wiring diagram late model 140
Posted by TheDurk on February 12, 2013 at 16:30:56 from (174.44.9.13):
In Reply to: Wiring diagram late model 140 posted by Haas on February 12, 2013 at 14:31:44:
Meanwhile, I can tell you:
Light switch Pin 3 (Yellow Wire) connects to Left Turn Flasher
Light Switch Pin 5 (Green Wire) connects to Right Turn Flasher.
It also says:
"The white, yellow, and green pins are factory pre-wired."
So I imagine you don't need to connect one switch to the other, unless somebody ripped something out. White is ground, by the way (Pin 1).
This post was edited by TheDurk at 16:37:05 02/12/13.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
